I’m trying to add a custom geojson file to geomap. I don’t see a way to select my own file from the options so I located the dropdown options in the geojsonLayer.ts file and added my own value there. The new file is located in the same /public directory as the other .geojson map files. However, this does not result in the expected behavior of that value being available. I’ve restarted the Grafana server thinking that might result in the uptake of the new TS file but no joy there.
What is the proper way to add a custom geojson file to Geomap? If it is editing the geojsonLayer.ts file how does one make the new option available?
It seems the choices are embedded in the code, however as a workaround custom files are permited if you upload your file to the folder (be aware that you can not delete the text in the GeoJSON URL selection box, you need to directly click and start writting the path and filename). At least that work for us. Thanks Grafana geojson team for working on the tool and to Peancor for finding this workaround.
Did anyone encounter: “Unable to parse locations” if you replaced one of the existing .json files with a custom one? I think it is not an issue with my json format.
In our case the file was uploaded to the “/public/gazetteer” folder, and in the GEOMAP option of data layer we typed the Geojson URL as: /public/gazetteer/image.geojson
Hope it helps!
Thanks! It’s hard to notice that one can write a custom path there.
If anybody is trying to get it to work with german postal codes:
Get the file DE.tab here:
And then run the following python script in that folder:
import sys
import pandas as pd
import json
dat = pd.read_csv("DE.tab",sep='\t')
dat = dat[dat["plz"].notnull()]
dat = dat[dat["lat"].notnull()]
dat = dat[["plz","lat","lon","name"]]
dat.columns = ["key","latitude","longitude","name"]
for i,row in dat.iterrows():
if "," in row["key"]:
for alt in row["key"].split(','):
tmp = row.copy()
tmp["key"] = alt
dat = dat.append(tmp,ignore_index=True)
dat = dat[~dat["key"].str.contains(",")]
parsed = json.loads(dat.to_json(orient='records'))
tmp = json.dumps(parsed, indent=4, ensure_ascii=False).encode('utf8')
print(tmp.decode())
I have set up a server that serves geoJSON files and thought that I could have grafana query my server for the files by adding the url to the server as stated above, but it does not show me anything. Have anyone managed to do this?
i need to know more on this. Where is your node.js located? on the same Grafana server? I have about 700 geojson files, and statically assining them is a pain.
