Hello
I want to create a layer on my map displaying static GeoJSON data from a file within the gazetteer folder. I know you can do this in the standard geomap panel but has anyone done it with the orchestracities map panel plugin?
Hello
Check this out
https://localhost:3000/t/adding-custom-geojson-to-geomap/57991/12
And this
https://localhost:3000/t/geomap-represent-data-with-coloured-areas/67616/27
Do you know if its possible to use css styling on the geojson shapes?
what are you attempting to do. and since this thread is closed might want to open a new one?
I created a new thread
https://localhost:3000/t/orchestracities-map-panel-geojson-styling/74439
