Trying to add the x-api-key header to a webhook contact point for use with aws api gateway, but the cloudwatch logs are showing it fails because ‘API key was required but not present’. Testing with postman using the same header/api key works fine. Am I missing something simple here?
Grafana version: 9.1.6
You are missing that is a Authorization Header - Scheme and not header key, so you are sending header:
Authorization: x-api-key <API-KEY>
but you need header:
x-api-key: <API-KEY>
Webhook doesn’t support custom headers.
I would recommend to create custom authorizer (Lambda) in your API GW, where you will be checking basic auth, because basic auth is supported by Grafana webhook.
