The annotations documentation for ES says it can support array or CVS for tags but I can’t figure our the syntax, a single field works fine.
Whats the syntax for multiple fields in annotations tags?
If you have a property, let’s say tags, in your es document and that property is an array you should only need to insert the name of that field in the tags field when configuring annotations.
Marcus
