Anonymous Authentification in a Docker Container
I am using the official grafana docker
I want to set Grafana to Anonymous Authentification
As per the Grafana documentation page, I can change the grafana.ini using the syntax ’ GF_<SectionName>_<KeyName>
I tried both
GF_auth_anonymous=true
and
GF_auth_anonymous_enabled=true
but without any success.
Can some body tel me how to enable Anonymous Authentification in a Docker Container?
Try:
GF_AUTH_ANONYMOUS_ENABLED=true
Thanks Jangaraj
It works
IT seems that all letters should be capital letters
Sorry to resurrect an old thread – But GF_AUTH_ANONYMOUS_ENABLED=true is not working for me within docker. the default.ini in the docker container still shows the setting as false, even after a recreate.
Any ideas? Has this changed? Can’t find anything in the documentation further than this.
You should pass GF_AUTH_ANONYMOUS_ENABLED=true
as Docker Environment variable
