Hey Guys,
I’m trying to display the following data coming from InfluxDB, where HOSTNAME is a tag and download is a Field:
I can easily get the data I want from influx with the query below:
select top(lastDown,hostname,3) from (SELECT last(“download”) as lastDown FROM “OUTLAND.Remote.Network.FW.Summary.Bandwidth.day” group by hostname)
and also I can properly display it on Grafana using a Table object.
The problem is when I try to present the data using a Bar Gauge panel it doesn’t work and shows like this:
As you can see above, where it should show hostname it displays TOP.
Can anyone help me figure this out ? Thanks in advance
