Candlestick questions
    Grafana 8.3, Ubuntu
    I am running performance tests on application elements and want to indicate the variability of all the tests within a run, and also how the performance varies over builds (not over time).
I also wanted to show the number of test results for each build, to give an indication on how reliable the results were.
    I am trying to use a candlestick panel where each candlestick represents the variation of a single performance metrics within a build, and the builds are the X-axis.
I’ve defined 25% as Open, 75% as Close, and min and max as Low and High. This should give the central 50% range as the candle and the min-max line as the wick.
  • What happened?
    I can’t find a method of telling the panel that the X-axis is not a time series, but should be taken from another column in the query.
My data is not especially grouped by time although repeated test runs tend to be on the same day or consecutive days so I grouped by time(24h) and at least I get something that has a bar of differing length per day.
    I expected the X-axis to either automatically be the first “group by” or at least I could change the panel config to select the column that should be the x-axis.
    SELECT percentile(“ok”, 25) AS “Open”, percentile(“ok”, 75) AS “Close”, min(“ok”) AS “Low”, count(“ok”) AS “Volume” FROM “autogen”.“gatling” WHERE (“build” =~ /^$BuildNumber$/ AND “profile” =~ /^$Profile$/) AND $timeFilter GROUP BY time(24h)
    No
    The only documentation I could find: Candlestick | Grafana documentation
I believe that the candlestick panel is based strongly on the time series panel, and that panel always assumes that time will be the x-axis. Sorry!
from the candlestick docs:
The Candlestick panel builds upon the foundation of the time series panel and includes many common configuration settings.
The bar chart can use string values along the x-axis, however:
We plan to add a Box plot panel in the future, which will support labeled/non-time x and is probably more appropriate for this.
1_CqdMwNZY5TZh42SgLaBCnA
Thanks both for your comments.
Box plot looks to be what I want, but I am going to have to find an approximation until it arrives.
At least I know to give up on the Candlestick.
