How to use candelstick visulation
Hello
i have some measurements about temperature all 15minutes new data.
i would like to create a Candelstick daily basis - but i only get a dotet line
have a nice day
Hi @vikozo,
Thanks for opening this post.
Did you already check the documentation regarding it i.e.
Also, found a very detailed explanation as how to use it for time-series data via this link and even though you are using InfluxDB, will still give you good information as how to make it work.
I hope this helps.
