Check if Metrics are Consumed by Dashboard
    v8.3.3
    Gather information if particular metric is consumed by one of the dashboard.
is possible to check if some (Prometheus) metric is used in (any) Grafana dashboard that we have? Mayby using API call(s)?
Thanks for help.
Lumir
There is no such feature natively in Grafana, but you could alternate solution like :
https://localhost:3000/t/is-there-a-way-to-list-all-dashbaords-that-use-a-datasource-in-grafana/16324/3
Hope it helps.
Good Luck
Many thanks, that’s what I was looking for.
L.
