Connect to Aws RDS on Postgres
i’ve some troubles connecting from Grafana cloud base to my postgres instance on AWS RDS.
I get this error:
dial tcp 35.157.101.40:5432: getsockopt: connection timed out
with theese parameters:
host: test-euris.c6farfmy0q1w.eu-central-1.rds.amazonaws.com:5432
ssl mode disable
Could you help me?
Salvatore
Are you sure no firewall is blocking access? The postgres port is blocked for me.
%  nmap -p 5432 test-euris.c6farfmy0q1w.eu-central-1.rds.amazonaws.com -Pn
Starting Nmap 7.60 ( https://nmap.org ) at 2018-02-15 17:55 CET
Nmap scan report for test-euris.c6farfmy0q1w.eu-central-1.rds.amazonaws.com (35.157.101.40)
Host is up.
rDNS record for 35.157.101.40: ec2-35-157-101-40.eu-central-1.compute.amazonaws.com
PORT     STATE    SERVICE
5432/tcp filtered postgresql
Hi svenklemm,
i can connect succesfully from my machine with pgAdmin so i guess there’s no blocked port.
But is the grafana host allowed to connect to the postgres database? Connection timeout might be firewall issue,
@svenklemm - how can I check that? I am running to a similar situation, on amazon.
I tried different postgres versions…
I used all default configurations on AWS except for the ones they require (like username).
Still I am unable to connect from Grafana. Tried all SSL options.
Hi, I have the same issue with cloud base Grafana. I can’t connect to AWS RDS MySQL in my case. I can connect to DB from PC using MySQL Workbench without any issue, but it is not possible from Grafana hosted by grafana.net. Have you solved your issues?
Hi there! What you’ll need is to whitelist the Grafana Cloud IP addresses in AWS. You’ll find them here: Cloud Portal | Grafana Labs
