Debian 11, Grafana v9.3.2, Influx v2.6.1 -
Create a table panel with information like disk size, states for each disk on the system like this:
Disk name | Capacity | Status |
disk1 | 500 | Ok |
disk2 | 1000 | Pre-failed |
Information are gathered using telegraf with a configuration like this. Finally, information are stored like that:
What happened?
The best I have is this
A row for each disk containing capacity, state… -
"id": 30,
"gridPos": {
"h": 12,
"w": 8,
"x": 0,
"y": 23
"type": "table",
"title": "Physical Disk Status",
"transformations": [
"id": "labelsToFields",
"options": {
"mode": "columns",
"keepLabels": [
"disks-name"
"id": "joinByField",
"options": {
"byField": "disks-name",
"mode": "outer"
"datasource": {
"uid": "000000003",
"type": "influxdb"
"pluginVersion": "9.3.2",
"fieldConfig": {
"defaults": {
"custom": {
"align": "center",
"displayMode": "color-background-solid",
"inspect": false,
"filterable": true
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"color": {
"fixedColor": "transparent",
"mode": "fixed"
"overrides": []
"options": {
"showHeader": true,
"footer": {
"show": false,
"reducer": [
"sum"
"fields": "",
"enablePagination": false
"frameIndex": 2,
"sortBy": [
"displayName": "_value {_field=\"disks-capacity\", _start=\"2023-01-05 11:37:20.937 +0000 UTC\", _stop=\"2023-01-05 11:42:20.937 +0000 UTC\", agent_host=\"192.168.33.10\", disks-name=\"Physical Disk 0:1:6\", host=\"influx\", system-name=\"idrac-57M3H92\"}",
"desc": true
"targets": [
"datasource": {
"uid": "000000003",
"type": "influxdb"
"refId": "B",
"hide": true,
"query": "from(bucket: v.bucket) \n |> range(start: v.timeRangeStart, stop:v.timeRangeStop)\n |> filter(fn: (r) =>\n r._measurement == \"idrac-hosts\" and\n r[\"system-name\"] == \"${host}\" and\n r._field == \"disks-name\"\n )\n |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)"
"datasource": {
"uid": "000000003",
"type": "influxdb"
"refId": "C",
"hide": false,
"query": "from(bucket: v.bucket) \n |> range(start: v.timeRangeStart, stop:v.timeRangeStop)\n |> filter(fn: (r) =>\n r._measurement == \"idrac-hosts\" and\n r[\"system-name\"] == \"${host}\" and\n r._field == \"disks-capacity\"\n )\n |> last()\n"
"datasource": {
"uid": "000000003",
"type": "influxdb"
"refId": "D",
"hide": true,
"query": "from(bucket: v.bucket) \n |> range(start: v.timeRangeStart, stop:v.timeRangeStop)\n |> filter(fn: (r) =>\n r._measurement == \"idrac-hosts\" and\n r[\"system-name\"] == \"${host}\" and\n r._field == \"disks-state\"\n )\n |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)\n |> keyValues(keyColumns: [\"disks-name\"])"
"datasource": {
"uid": "000000003",
"type": "influxdb"
"refId": "E",
"hide": true,
"query": "from(bucket: v.bucket) \n |> range(start: v.timeRangeStart, stop:v.timeRangeStop)\n |> filter(fn: (r) =>\n r._measurement == \"idrac-hosts\" and\n r[\"system-name\"] == \"${host}\" and\n r._field == \"disks-predictivefail\"\n )\n |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)"
"description": ""
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
nothing
- Did you follow any online instructions? If so, what is the URL?
I can only paste one other so, I’d say this one:
Thanks!
