CSV Export Not Exporting Correct Time Range
I am having an issue exporting data. When I export data from a line graph as a CSV, I get all data for the data points I have selected, not just the data in the selected time zone.
So for an example if I have been collecting data since September 1st, and I zoom into the data for today only and export, I get the data since September 1st not just today.
I am using Grafana 4.5.2 and crate.io for my database.
Does anyone know how to fix this?
I have the same problem.
If this is the normal behavior, could this be a feature request?
Thanks.
It’s solved for me. It was my fault.
In the mysql query I forgot to put the WHERE clause as suggested in the example shown by default when you add a new query. The clause I had left out was:
“WHERE $__timeFilter(time_column)”
