Hi!
I have read from the docs that k6chaijs
has better error handling than checks
so I’m using describe - expect in my k6 frontend tests.
What would be a proper way to create a custom metric for failing expects, count of total tests executed and use this as threshold (to make sure that expects were actually executed), just like the check would? Thresholds
In this sample snippet, I would need to place this inside a try-catch block because otherwise, I would get
ERRO[0015] Uncaught (in promise) Error
running at ue (https://jslib.k6.io/k6chaijs/4.3.4.3/index.js:2:1165(57))
frontendat https://jslib.k6.io/k6chaijs/4.3.4.3/index.js:4:55024(125)
That also means that the catch block becomes the catch all for any error, like navigation timeout, in theory.
describe('Sample describe block', async () => {
try {
expect(1, `1`).to.equal(2);
} catch (error) {
console.error(error);
} finally {
// this is run on k6 browser
await page.close();
await browser.close();
I would like to use these in my thresholds and define whether or not to abort the run if the expects have been failing.
Thanks in advance for the guidance!
