Here is my code:
------mainScript.js-------
import { group, sleep} from "k6"
import tc1 from './testcase_1.js'
import tc2 from './testcase_2.js'
export let options = {
thresholds: {
failedRequestCounter: [{ threshold: 'count===0', abortOnFail: true }], // abort the test on any failed requests
vus: 1,
iterations: 1
export default function () {
tc1();
tc2();
----testcase_1.js-------
import http from 'k6/http'
import { sleep } from "k6";
import * as checkHelper from './checkHelper.js'
vus: 1,
iterations: 1
let res;
res = http.get('https://test-api.loadimpact.com/public/crocodiles/a') // 404
checkHelper.check(res.status, {
"some other check in test case 1": (status) => status === 201
sleep(1);
-----testcase_2.js-------
vus: 1,
iterations: 1
let res = http.get('https://test-api.loadimpact.com/public/crocodiles/');
"API in test case 2 is working": (status) => status === 200
----checkHelper.js-------------
import { check as loadTestingCheck} from "k6";
import { Counter } from 'k6/metrics'
export let failedRequestCounter = new Counter('failedRequestCounter');
export let check = function (obj, conditionArray, tags) {
let result = loadTestingCheck(obj, conditionArray, tags || {});
failedRequestCounter.add(!result);
return result;
---run script---
k6 run mainScript.js
done [==========================================================] 0 / 1
WARN[0002] No data generated, because no script iterations finished, consider making the test duration longer
✗ some other check in test case 1
↳ 0% — ✓ 0 / ✗ 1
checks.....................: 0.00% ✓ 0 ✗ 1
✗ failedRequestCounter.......: 1 0.504474/s
----the test case 1 failed as I expected and the whole test is stopped before testcase_2.js is run. However, I don’t understand how this could work when checkHelper.js is only imported by child scripts, and the failedRequestCounter is only defined there, but not in mainScript.js even though the threshold is only set in mainScript.js.
My second question is: if I remove sleep(1) from testcase_1.js, the test case_2 will be executed even though failedRequestCounter reached the failure threshold. I am not sure if it has been documented that sleep(1) is required in order for data is returned to metrics.
