Datasource named nagflux was not found
I am running grafana-6.6.0 on CentOS Linux release 7.7.1908 (Core) using influxdb as timeseries database 1.7.9. I have added it in datasource and tested it. It works. I have queried the influxdb i am able to see the data but when i query it from Grafana UI dashboard, i am seeing Datasource named nagflux was not found
select * from metrics where host='localhost' limit 5;
time                command           crit   crit-fill crit-max crit-min host      max    min performanceLabel service         unit value warn   warn-fill warn-max warn-min
1579915992000000000 check-host-alive  100    none                        localhost        0   pl               hostcheck       %    0     80     none
1579915992000000000 check-host-alive  5000   none                        localhost        0   rta              hostcheck       ms   0.037 3000   none
1579916122000000000 check_local_disk  138229 none                        localhost 153588 0   /                Root Partition  MB   9846  122870 none
1579916122000000000 check_local_procs 400    none                        localhost        0   procs            Total Processes      87    250    none
1579916122000000000 check_local_users 50     none                        localhost        0   users            Current Users        1     20     none
Best Regards,
Kaushal
Hi!
Could you please show how your InfluxDB data source is setup?
