Grafana Datasource XY not found
Hello, everyone.
I’m having a problem with connecting Grafana with InfluxDB.
I’m using Grafana to get graphs from Nagios Core (Using InfluxDB + Nagflux + Histou), according to: https://support.nagios.com/kb/article.php?id=802
Integration works OK. InfluxDb’s database named “nagflux” is filled correctly with data from Nagios Core, but I can’t connect Grafana with it. Irony is that I created datasource type InfluxDB with database “nagflux”, and I got green message “Data source is working”.
But, when I try to get graph via link: http://192.168.120.201:3000/dashboard/script/histou.js?orgId=1&host=localhost&service=PING&refresh=30s , I got error message in red triangle in left corner “Datasource named nagflux was not found”
My config:
Debian 10 (buster)
PHP 7.3.27-1~deb10u1
Grafana v7.4.3
InfluxDB v1.6.4
I saw similar post a year ago, without solution.
Did someone succeeded to solve the problem?
Thx.
finally i found the cause . Name should be nagflux . Since it was influx by default , you might have left it as its .
