Hi, thanks in advance!
I’m using Grafana to get graphs from Nagios Core (Using InfluxDB + Nagflux + Histou), according to: Nagios Core - Performance Graphs Using InfluxDB + Nagflux + Grafana + Histou
InfluxDb’s database named “nagflux” is filled correctly with data from Nagios Core(nagflux), but I can’t connect Grafana with it. Irony is that I created datasource type InfluxDB with database “nagflux”, and I got green message “Data source is working”.
influxdb → 1.8.10-1
Nagios → core 4.4.6
Grafana → v8.2.5
Histou → 0.4.3
PHP → 7.0.27
Centos → 7.9.2009
Histou show all data in json correctly, but whith the grafana integration (histou.js) shows an error in grafana dashboard:
"gridPos": {
"x": 0,
"y": 0,
"w": 24,
"h": 8
"type": "text",
"title": "Error Message below",
"fill": 1,
"content": "# HTTP code: 200\n# Message: load\n# Url: http://nagiosserver/histou/index.php?host=server1.es&service=&height=&legend=true&annotations=false\n# Probably the output is not valid json, because the returncode is 200!",
"options": {
"mode": "markdown",
"content": "# Title\n\n For markdown syntax help: [commonmark.org/help](https://commonmark.org/help/)\n "
"id": 1,
"pluginVersion": "8.2.5",
"datasource": null
I can´t resolve this! is there any way to solve it?
Thanks!!
