"Datasource Updated", "Database Connection OK" but "No Data"
Grafana version: 7.5.7
Operating system: Windows 10 Enterprise
    Create a dashboard.
    Add a datasource (tried with MS SQL and now with MySQL
  • What happened?
    No Data
    Data to create dashboard
    Please see screenshots (to be uploaded).
MS SQL:
MySQL:
For more details on the problem when I used MS SQL as the default datasource, see: https://localhost:3000/t/how-to-write-ms-sql-queries/48287/2
Was advised by a colleague to configure the panel, i.e. set the Relative Time Range by clicking the up arrow in the Top Right area. After setting the time range, the graphs appeared just fine.
so glad you found a solution!
I am glad too ◡̈ Thank you for the “Like”.
