first of all, sorry for my bad english.
I have a problem with the display of a graph within a period selected by Grafana.
I run a small PV system. Here the data is entered in a MySQL database.
The structure of the database is as follows:
table name:
iobroker
Tables:
datapoints (e.g. column: ID=44, name=mqtt.0.inverter.Hoymiles-HM-600.ch0.YieldDay and type=0)
sources
ts_bool
ts_counter
ts_number (e.g. column: ID=44, ts=1,680,771,015,900, val=488, ack=1, _from=3 and q=0
ts_string
The graph is correct so far, but the displayed MAX value is not that of the selected period, but from the beginning.
With an InfluxDB, the code looks like this:
SELECT mean(“value”) FROM “mqtt.0.inverter.Hoymiles-HM-600.ch0.YieldDay” WHERE $timeFilter GROUP BY time($__interval) fill(null)
My MySQL code:
SELECT FROM_UNIXTIME(ts/1000),val as ‘Power’ FROM iobroker.ts_number WHERE id=44
GROUP BY is missing here. How do I do this?
SELECT FROM_UNIXTIME(ts/1000) AS Zeit, val FROM iobroker.ts_number WHERE (id=55 and FROM_UNIXTIME(ts/1000) > DATE_SUB(NOW(),interval 2 hour)) ORDER BY Zeit DESC;
works the way I want. Can someone help me there again as I do the part
replace “> DATE_SUB(NOW(),interval 2 hour)” with the selected time filter?
