Drill down / detail link
I want to use the functionality described in the documentation:
When linking to another dashboard that uses template variables, you can use var-myvar=value to populate the template variable to a desired value from the link
How exactly I do that, I have been able to call to another dashboard and in the URL I can see the variables, but I do not know how should I define the variables in the destination dashboard.
Thank you for your help
I found the solution, you only need to define the same variables name in the child dashboard from the parent.
I hope this help to someone else
Hi , i’m begining with grafana and i tried to do wath you did, but it’s not very clear for me. could you explain me more how to do that please
You have to put in the URL: I hope this helps you
[/uploads/grafana/original/2X/b/b263e75ffd0effdf30dd5c53e95c1a6f10ccb894.png]
[/uploads/grafana/original/2X/d/d9c73ff4157d608cec39eefe99d6f3f16aa4f4dd.png]
[/uploads/grafana/original/2X/6/633fa32b8605318c5f28dfd24151b3ccbc67a6b9.png]
I upload the images here
Thank you very much. it’s working very well
Hello
I also tried to do this but the pictures aren’t very clear to me.
Can you show a picture of the variable in the destination dashboard (how do you get the value of the variable in the url)?
Thank you!
