Hello.
I’ve checked several ways to configure links to dashboards based on template variables, but without any success.
Let me describe the problem:
- I want to have single dashboard with template variable e.g. “service_name”={“app1”, “app2”}
(app1, app2 - names of applications which is fetched from prometheus and it’s not hardcoded values); - I want to have the list of dashboards which depends on this “service_name” parameter e.g. shows all dashboard with title app1.* or app2.* (depends on chosen value of $service_name parameter)
Possible solutions:
Using of dashboard list
It will be nice just put $service_name in field “Query” of Dashboard list, but i’ve found that it isn’t supported:
https://github.com/grafana/grafana/issues/7595
(also checked it on Grafana v5.4.3 - still doesn’t work)
So, “Query” filed is restricted by using of hardcoded values, it’s sad. -
Using of Drilldown / detail link
2.1 With “dashboard” type:
“Dashboard” field have the same problem as “Query” in dashboard list - template variables doesn’t work (but at the same time it works well with “Title” and “Url params” fields.
2.2 With “absolute” type:
“URL” field support template variables, but it’s doesn’t allow to fetch dashboards from grafana itself, dashboard name can be just calculated somehow.
The question - is there way to configure dashboard list; drilldown llinks (or maybe there is some another plugin) for querying dashboards based on template variable (instead of hardcoded value)?
Many thanks!
