Greetings
Is it possible to do dual axis for bar chart to show some trendline? I have configured two overrides but does not show the second axis.
Sample data
metric,value,trend
A,1,2.5
B,3,2.5
C,2,2.5
D,4,2.5
E,3,2.5
Greetings
Sample data
metric,value,trend
A,1,2.5
B,3,2.5
C,2,2.5
D,4,2.5
E,3,2.5
Hi!
Were you able to solve this ?
I find myself trying to do the same ,
Thanks in advance
hello,
You can check this post maybe,
https://localhost:3000/t/is-it-possible-to-overlay-2-graphs/55587
had kind of same issue, i would display forecast on top of other line.
i could get it through time series panel.
Hey @yosiasz
Also, this plugin can also help you out.
