I’m trying to get a dual Y Axis panel going. Trying to map Upload speed in (Mbps) on Left and Latency in (ms) on Right
For some reason the Right Y axis is not showing up in my case. And I cannot figure out how to associate the Latency dataset with the right axis. Here are my panel settings
My field settings are BLANK.
I will submit overrides image in next post. Discourse is preventing more than 2 links.
Any thoughts on how to solve this mystery. The Field Override section of the documents does not help
I’m using the UI embedded in Home Assistant, and I don’t see either of the options you describe anywhere. I can’t locate a “Panel” tab with a “Series overrides” option, and I do not see a “Y-axis” tab when I click the colored line from the panel legend.
