Grafana v9.3.6
I have a table with three columns: value
, min
and max
. These values come from a JSON datasource using the JSON API plugin.
I would like to change the color of the value column on each row based on its compliance (green) or non compliance (red) to the max/min. The issue here though is that the min/max aren’t static, they may vary on different rows.
Note that there are never both min and max on the same row, it’s either there’s a maximum value allowed or a minimum, never both, so I’m not dealing with a range.
I was wondering if there is a workaround to this since dynamic thresholds are not currently possible. I have already tried this solution which isn’t enough in my particular case.
If this isn’t possible in Grafana, I can add another field from my api configuration which determines for each row whether the value is in compliance or not to the targets (for example a yes/no or 1/0 value), but I’m not sure if in that case it will be possible to change the color of the value
field based on that as well.
I do not believe dynamic thresholds are possible in grafana.
can you handle this on your api side dynamically and send color value to grafan?
Yes I can add another field on my api side which does the calculation. However what I am trying to achieve is to color the value
cell itself, and in that case it would still have to depend on the value of another cell.
Hi, any idea which transformation can help me achieve my goal? I have already tried them all and found no workaround unless I am missing something…
That link is direct link to Config from query results
transformation.
Could you please further elaborate on how this transformation can be a solution?
Sorry, I gave you only a direction.
Found a solution by using this demo dashboard.
In my JSON API query fields, I created a new field called compliance
which is has two possible values green
or red
based on the values of value
and min
and max
The JSONata query looks something like this:
$map(*, function($v, $i, $a) {
($v.min != null and $v.value >= $v.min) or
($v.max != null and $v.value <= $v.max)
? 'green'
: 'red'
Then use the transformation Config from query results
following the same logic as the demo dashboard:
Last step:
Add a color background override to the value
field:
