What Grafana version and what operating system are you using? v8.4.3 on ubuntu
What are you trying to achieve? I’m trying to easily switch between different Grafana instances running on separate but identical kubernetes clusters
How are you trying to achieve it? Using a dropdown or similar UI feature – I only need to swap the hostname – urls can remain identical
Additional Info:
At my work, we run many kubernetes clusters, a few for production, a few for staging per team. Each kubernetes cluster has its own Grafana and shares identical dashboard JSON configuration and data sources. In general, you can replace the hostname of a given Grafana dashboard and see the same panels relevant to another kubernetes cluster (which is great!). However, I would like to just click a dropdown to switch between the clusters without having to type into the URL bar in my browser.
Is there a way to have a plugin override the UI of Grafana itself (not a panel)? Or a way to add links to the top or left navigation systems without forking Grafana?
