bmm_alc
1
I want to purge all chunks older than 31 days in loki so I set this config
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: "/var/lib/loki/boltdb-shipper-active"
cache_location: "/var/lib/loki/boltdb-shipper-cache"
cache_ttl: 24h
shared_store: filesystem
filesystem:
directory: /var/lib/loki/chunks
compactor:
working_directory: "/var/lib/loki/boltdb-shipper-compactor"
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: true
retention_period: 31d
version: 2.4.1
but this is not working.
Did I forget something to set ?
wlargou
2
Did you wait for deletion, there is a relevant discussion in Github i suggest you have a look at it first :
Hope it helps.
Good Luck
bmm_alc
3
actually starting in version 2.4.0
it’s necessary to update the configuration to purge old data, by
- defining the retention period in section
limits_config
- activate the retention in section
compactor
which gives
compactor:
retention_enabled: true
limits_config:
retention_period: [30d]
this is explained in the upgrade document I did not know about
Hello,The chunks are deleted or not? I’m having a problem with full disk space
Same here, getting disk space issue with loki 2.4.1. Did you got the solution
system
Closed
6
