Log retention configuration for loki is not working
Hi, I have below configuration for grafana loki . I am expecting that the chunks will be deleted after every 24hrs. But it is not working as expected.
auth_enabled: false
server:
http_listen_port: 3100
ingester:
lifecycler:
address:
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 30s
schema_config:
configs:
    store: boltdb
    object_store: filesystem
    schema: v11
    index:
    prefix: index_
    period: 24h
storage_config:
boltdb:
directory: /u01/app/grafana/loki/index
filesystem:
directory: /u01/app/grafana/loki/chunks
compactor:
working_directory: /u01/app/grafana/loki
shared_store: filesystem
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 1h
retention_delete_worker_count: 100
limits_config:
enforce_metric_name: false
reject_old_samples: true
reject_old_samples_max_age: 24h
retention_period: 24h
chunk_store_config:
max_look_back_period: 24h
table_manager:
retention_deletes_enabled: true
Need help in fixing the log retention issue.
Are they not being deleted at all, to early, or too late?
They are not being deleted at all.
Mine, too. Does anyone know why?
I’m experiencing the opposite issue… I just tried to configure log retention and my logs are disappearing after a couple of hours.
My understanding from the documentation is that the compactor and limits_config are relevant:
limits_config:
    limits_config:
      reject_old_samples_max_age: 168h
      max_cache_freshness_per_query: 10m
      retention_period: 336h
compactor:
    compactor:
      working_directory: /data/retention
      retention_delete_delay: 2h
      retention_delete_worker_count: 150
This is my complete loki config:
apiVersion: v1
data:
  config.yaml: |
    auth_enabled: false
    server:
    distributor:
      ring:
        kvstore:
          store: memberlist
    memberlist:
      join_members:
        - obs-loki-memberlist
    ingester:
      lifecycler:
        ring:
          kvstore:
            store: memberlist
      chunk_idle_period: 30m
      chunk_block_size: 262144
      chunk_encoding: snappy
      chunk_retain_period: 1m
      max_transfer_retries: 0
      wal:
        dir: /var/loki/wal
    limits_config:
    schema_config:
      configs:
        index:
          period: 24h
          prefix: loki_index_
        schema: v11
        store: boltdb-shipper
    storage_config:
      boltdb_shipper:
        active_index_directory: /var/loki/index
        cache_location: /var/loki/cache
        cache_ttl: 168h
        index_gateway_client:
          server_address: dns:///obs-loki-index-gateway:9095
      filesystem:
        directory: /var/loki/chunks
    chunk_store_config:
      max_look_back_period: 0s
    table_manager:
      retention_deletes_enabled: false
      retention_period: 0s
    query_range:
      align_queries_with_step: true
      max_retries: 5
      split_queries_by_interval: 15m
      cache_results: true
      results_cache:
        cache:
          enable_fifocache: true
          fifocache:
            max_size_items: 1024
            validity: 24h
    frontend_worker:
      frontend_address: obs-loki-query-frontend:9095
    frontend:
      log_queries_longer_than: 5s
      compress_responses: true
      tail_proxy_url: http://obs-loki-querier:3100
    compactor:
    ruler:
      storage:
        type: local
        local:
          directory: /etc/loki/rules
      ring:
        kvstore:
          store: memberlist
      rule_path: /tmp/loki/scratch
      alertmanager_url: https://alertmanager.xx
      external_url: https://alertmanager.xx
Update: I just realized I had a bug in my Helm chart values file where I was using the term ingestor instead of ingester so that may be part of my problem… My persistence settings were not applied so I’ll find out shortly if this makes the difference.
Could it be that the use of inmemory store is the cause here? If you restart your ingester, do the logs all disappear?
I am not sure how it actually works but it would not surprise me if the log retention settings didn’t apply to the inmemory storage as every time your ingester restarts, it would wipe the logs. Just a thought…
Check the file modification time of /var/loki/chunks directory. Are you sure that the chunks files in this directory are deleted? I think you can’t find the log because the index is deleted but the chunks file is still there
