Newest version 8.4.1
Centos 8 -
I would like to filter out some of the results from a JSON query before the variable is passed to the rest of grafana. When I try to use the filter option it never has any fields to filter on. I have only selected two columns so that it acts as a key:value pair. I have tried using the Regex filter but it appears to only filter out based on the value and not the key, the value is a random serial number and the key is a model number, I would like to filter out the model numbers that are not relevant. Unfortunately the Meraki OpenAPI I am using does not offer any filtering. -
I have tried many different methods.
Tried to find a different API that would allow for filtering, unfortunately if I use the one you can filter by model you can’t filter by network so similar issue.
I have tried using the filter option but it doesn’t appear to work for infinity json datasource.
I have tried to filter by regex which works but only against the value part of the pair and it need to filter based on the key. -
What happened?
Filtering doesn’t appear to work for infinity json datasource, I am open to using a different json api datasource but the others I tried didn’t allow for a generic url that doesn’t initially return a json result. The Meraki API url has to be changed so unless you can use a variable in the datasource this will not work for most of the other json api datasource options I saw. -
I expected to be able to use the filters, at least the grafana built in filters. -
No, it is not really erroring, just not filtering the correct column. -
Did you follow any online instructions? If so, what is the URL?
The documentation for the plugin is lacking, especially in the variable section. I have tried searching for other information and looking through the discussion boards on both grafana and the infinity plugin. I have also started a help request in the infinity git hub community but I think it is only a single guy doing it all and I know he must be busy with other things so I am just trying to seek out other expert advice.
Thank you for any help you all can provide, it will be much appreciated.
:Nick:
