When I use a query math expression with two previous elasticsearch queries, like the result of query A / by the result of query B: $A/$B . Give me the following error: “expression request error”.
What is missing?
Thanks.
can you share a screenshot of the error and any relevant logs?
Hello, I encounter the same problem. The expression $A + $B (or $A - $B) return a right result
but the expression $A / $B return a wrong value but no error.
And the expression ($A * $B) return 0.
I think thas is because of Grafana considere only “+” as a layering of these values, and don’t conside the count number as a number:
Anyway, I can’t tell to Grafana to consider only results as a count.
For information, I want to display percentage of deployments who provoked an incident (4 keys of DORA), so to display ($A / $B) * 100.
Somone have any idea ?
Thank you in advance
I am facing the same issue, +, - , * work fine for me, but the / (division).
When Min Doc Count set 0, it gave me an NaN, when set to 1, it gave me a unreasonable result.
Changing on the Interval in Date Histogram also had the similar behavior.
My Grafana version 8.0.6, Stat panel
