Grafana 8.1.1/2 lazy loading on mobile device not working
    8.1.1/2 Debian 9
    DB with 9 rows 3 panels per row. Only top 3 rows populate on mobile device (Android/iPhone) - all other rows blank except for row header. Refresh and wait 10s before scrolling down and everything good.
  • What happened?
    All rows populate as you scroll down page
    No
Hi @mallan
Are you still experiencing this? Is the behavior reproducible?
Hi Matt
Yep its still happening and it is reproducible. Can give you access if you wish to try it out for yourself.
Cheers
Marcus Allan
Director
0400 618433
Same for me
Grafana 8.12 on Ubuntu
Tried with Firefox for Android and Samsung Internet browser
Also rows that are collapsed do not load after being expanded. Just a big empty space there.
It appears panels that are in offscreen rows do not consistently load when scrolled to.
@mattabrams This is becoming a bit of an issue for us. Can you suggest a way we might try and figure out whats going on?
Hi @mallan,
sorry to hear you’re still blocked on this. Can I have your input: how closely does this issue describe your situation?
Matt
It appears to be the same issue. From a device perspective, for us this issue is mobile only (Android/iOS) and Chrome. We have not extensively tested other browsers.
My original post suggested that it might be a row based problem. I removed all rows from the dashboard this morning and left just the 27 panels. The problem still occurs.
Marcus
I would hop on that GH thread and try to provide the team with a reliable way to reproduce your issue. that’s the best way to get :eyes: on this
@mattabrams - the GH issue is closed. Do I raise a new issue and reproduce the content I have put up here?
yes, and link to the old one. Ideally, provide a quick and reliable way for the teams to test this :+1:
