Grafana Cloud, latest -
I am trying to connect Grafana cloud to my local PostgreSQL instance to test it out using the PDC agent. -
I followed this whole guide, that is pretty straightforward: Configure Grafana private data source connect | Grafana Cloud documentation
I am running this locally, so Grafana is available from there. I tried with two different approaches
- Docker
- Binary
- What happened?
None of the two solutions tried worked. When trying to connect, the PDC agent gets a connection timeout when trying to reach the Grafana server, like it’s unavailable.
Grafana Cloud status shows that everything is operational. https://status.grafana.com/
For information, I am using Grafana cloud free as a trial. I do not have any error indicating that this is a paid feature anywhere either in Grafana’s UI or the PDC agent.
- What did you expect to happen?
Obviously, I expected the agent to connect successfully, the procedure to connect it is very straightforward.
