Grafana OSS Version 9.2.0 -
I’m trying to embed Grafana dashboards in an Iframe of a React UI using nginx as reverse-proxy and auth.proxy authentication -
- Configured nginx as reverse proxy to grafana (following official docs) - OK works
- Configured Grafana to permit embedding, subpath and root_url accordingly with best practices - OK works
- Enabled auth.proxy in grafana.ini, disabled anonymous mode, disabled autosignup (for security purposes)
- Create a simple page with JS that populates iframe tag with dashboard url and adds X-WEBAUTH-USER header with valid viewer user existing on Grafana.
Tried also Service Account with token Bearer and adding “Authorization: bearer ” on headers.
<iframe width="800" height="800"></iframe>
<script>
async function getSrc() {
const res = await fetch("https://<my-grafana>/grafana/d/3XsD-HSVk/dash?orgId=1&refresh=10s&theme=light&kiosk=1", {
method: 'GET',
headers: {
// Here you can set any headers you want
"X-WEBAUTH-USER":"my-user"
const blob = await res.url;
console.log(blob);
document.querySelector('iframe').setAttribute("src", blob)
getSrc();
</script>
What happened?
There is the first GET that ends with code 200 OK, than Grafana redirects with a 302 and the standard login form is loaded… There’s a redirect to cookie to /grafana/login. -
The dashboard is loaded and so the authentication is seamless… -
Did you follow any online instructions? If so, what is the URL?
https://grafana.com/docs/grafana/latest/setup-grafana/configure-security/configure-authentication/auth-proxy/
https://grafana.com/tutorials/run-grafana-behind-a-proxy/ -
Configurations:
nginx:
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream grafana {
server localhost:3000;
server {
server_name myapp.com;
location / {
root /usr/share/nginx/html/myapp/;
index index.html index.htm;
try_files $uri $uri/ /index.html;
location /grafana/ {
rewrite ^/grafana/(.*) /$1 break;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto "https";
proxy_pass http://grafana;
location /grafana/api/live/ {
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
grafana.ini
[server]
domain = myapp.com
enforce_domain = true
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
serve_from_sub_path = true
[security]
allow_embedding = true
[users]
allow_sign_up = false
[auth.proxy]
enabled = true
header_name = X-WEBAUTH-USER
header_property = username
auto_sign_up = false
sync_ttl = 60
whitelist = 127.0.0.1
enable_login_token = true
The question is:
Is it possible to embed Grafana inside an iframe in a Webapp, implementing nginx as reverse proxy and a secure authentication without inserting credentials in the classic form?
thanks in advance!
