I had a strange situation integrating grafana with a reverse proxy
Browser successfully redirected to grafana’s home page when I enter my proxy address directly on the browser
But when I use iframe to integrate grafana, the interface doesn’t redirect and stays in the login url
url: http://localhost:9091/grafana/login?username=admin
html:
this is a iframe test
This is my nginx configuration
server {
listen 9091;
server_name localhost;
error_log logs/grafanaError.log debug;
location / {
root html;
index index.html index.htm;
location /grafana/ {
#proxy_set_header X-WEBAUTH-USER "zanebono";
proxy_set_header X-WEBAUTH-USER $arg_username;
proxy_pass http://grafana.staged-by-discourse.com/;
grafana configuration
[auth.proxy]
enabled = true
header_name = X-WEBAUTH-USER
header_property = username
auto_sign_up = true
sync_ttl = 60
whitelist =
headers =
Read the auth proxy docs for details on what the setting below enables
enable_login_token = true
Any help is useful, thank you!
