Grafana 9.3.6 on ubuntu 20.04 -
I want to display info on a table from multiple jobs running on multiple nodes (overview of 2 jobs: node exporter and GPU exporter running on multiple nodes) -
I have extracted the needed information from the jobs with different prometheus queries and used concatenate fields transformation to show each node on a row. -
What happened?
data from different jobs are overlapping and in one row you can see in the screenshot it is concatenating data from different IPs in a single row:
each row to have one single IP -
Happy to provide if necessary -
No -
Did you follow any online instructions? If so, what is the URL?
No
Hi @omarifwalid,
Welcome to the community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
If I understand correctly, the problem is that the column “IP (Link to details)” gets repeated in each row multiple times and you do want it as to only appear in the 1st position?
Can you please try to reproduce this same issue on https://play.grafana.org/ and then share the dashboard link so that we can view it?
OR
Share your Dashboard (if possible) or export it so we can import it and see if we can understand it better.
