My project just received one requirement that need to transform from
to
Does the table panel have such way of aggregation ?
to
Which datasource are you using ?
Good Luck
Did you check the Concatenate Field in the transform tab ?
Good Luck
I use Prometheus, thx bro
It seems Concatenate Field doesn’t help
Unfortunately i think what you are looking is more like this feature request :
(You can upvote it)
Good Luck
