Grafana version 9.1.2 on RHEL
I need to map results from different (Prometheus)queries into a table with ‘sets of columns’
In a table panel I have 3 queries (Active, Errors, Warnings) leading to following result sets
Query Key SQ Value
Active X 1 1
X 2 1
X 3 0
A 1 1
A 2 1
A 3 0
Errors X 1 1
X 2 0
X 3 0
A 1 1
A 2 0
A 3 0
Warnings X 1 2
X 2 2
X 3 0
A 1 2
A 2 2
A 3 0
With following transformations, I can put the results for the metrics on one line.
- Filter by Name : to exclude some columns
- Merge
- Organize Fields : to rename fields
Key SQ Active Errors Warnings
X 1 1 1 2
X 2 1 0 2
X 3 0 0 0
A 1 1 1 2
A 2 1 0 2
A 3 0 0 0
Next I want to bring together the values per sequence, but I don’t know how to use the Rows to Fields mapping to achieve the following
Key SQ-1 Act-1 Err-1 Warn-1 SQ-2 Act-2 Err-2 Warn-2 SQ-3 Act-3 Err-3 Warn-3
X 1 1 1 2 2 1 0 2 3 0 0 0
A 1 1 1 2 2 1 0 2 3 0 0 0
A finally remove the SQ columns
Key Act-1 Err-1 Warn-1 Act-2 Err-2 Warn-2 Act-3 Err-3 Warn-3
X 1 1 2 1 0 2 0 0 0
A 1 1 2 1 0 2 0 0 0
Can I use Rows To Fields transformation or is there another way to achieve this?
