grafana version:4.6
zabbix version:3.4
now,I have a value of type key value like time:value in zabbix database , can i use time as X-axis,value as Y-axis,and The Y-axis changes as the value of time(X-axis) changes.tip:zabbix database is mysql.
grafana version:4.6
zabbix version:3.4
You can, but grafana supports only timestamps as a source for X axis. So you can’t set arbitrary units for X axis. So even if you select values for X axis, you’ll see time units.
