How can display how many alerts are been triggered using a single stat panel?
    Latest Grafana version and Windows 10
    I have created some alerts on my line graph and have used telegram to notify me. This is working perfectly fine. Now I want to display the count of the alerts. I want to display how many alerts have been triggered until now using a single stat panel.
    I have no idea how to do it.
  • What happened?
There is a question that another user has asked the same as me, but he’s using Prometheus and I am using MYSQL database.
https://localhost:3000/t/count-active-prometheus-alerts/629
this might not work for you and I believe it only interfaces with the API for legacy alerting, but it might be worth exploring:
