How do I permanently customize time range in my panels?
I succeeded in displaying different time ranges in my different panels in my dashboard: so e.g. I can have one panel displaying data from last week, one panel displaying data from last month, etc. I succeeded in doing so by selecting custom time ranges within each panel.
The problem is that when I revisit my dashboard (edit: even if I click the ‘Refresh dashboard’ button), all times will be within the same time range. Even when I edit a panel its time range gets reset to whatever the time range was of the previous panel that I edited.
I need to know how to make the time range permanent and I hope someone can help.
I am using Grafana version 7.1.3.
Hi @martijnbouman you should be able to override this per panel with query options - check out the time range docs - -> https://grafana.com/docs/grafana/latest/dashboards/time-range-controls/#panel-time-overrides-and-timeshift
Thank you for the explanation.
