Different time settings per Panel
I want to use different time settings per panel to display the data of the last 3 work shifts and the current data.
Is there a way to assign the “time selector” to each panel without sharing it on the whole dashboard?
The Database I’m using is InfluxDB.
Best regards from Germany.
Hi @jherbstlich - you can customize the time settings per panel by doing overrides with query options: https://grafana.com/docs/grafana/latest/dashboards/time-range-controls/#panel-time-overrides-and-timeshift
