Hi
On the grafana website there is a status history panel like the below
What does the data need to look like for this to work?
I’ve got a simple sql query that gives me
- server name
- timestamp
- value
or simply put, something like this:
select
systemKey
,time
,pr
from mytable
where time between $__timeFrom() AND $__timeTo()
However, everything ends up squashed up
Table view:
Hi @xbalayer
I believe that the Status history panel expects data as a simple data frame (timestamp, single value). You will note on the example on play.grafana.org that each row in the status history is returning a distinct time series, and that series contains only timestamps and single values.
Try splitting your query up into multiple queries, where each returns the values for an invidual system, like this:
Note the dropdown when viewing this in the table panel, which means that there are multiple series to choose from. This is what you want to achieve. This renders like so in the Status History panel:
Thank you, that explains it well.
Unfortunately it won’t work for my specific use-case as I have a dynamic set of series and there is no way to “repeat” queries based on each series.
My workaround was to use a normal table with coloured cells by pivoting the query in SQL:
Hello xbalayer, I’m trying to do something similar with some data I have as well. Is it possible you can share a little more details on how you did this. I have 3 fields similar I’m trying to show in my panel but i have no idea how to configure the table to show it how you have it above. Any assistance would be greatly appreciated.
Hi @terrancej
My data is in SQL Server, so this only really applies if you are using a SQL database. This can also be slightly improved code-wise with SQL Server 2019, but this will work either way.
Since I wanted to make the days dynamic both the columns in @cols and query in @query needed to be dynamic too.
DECLARE @cols AS NVARCHAR(MAX), @query AS NVARCHAR(MAX)
select @cols = STUFF((SELECT distinct ',' + QUOTENAME(CAST(timestamp AS DATE))
from vcom.dbo.system_daily_pr where timestamp between $__timeFrom() and $__timeTo()
order by ',' + QUOTENAME(CAST(timestamp AS DATE))
FOR XML PATH(''), TYPE
).value('.', 'NVARCHAR(MAX)')
,1,1,'')
set @query = 'SELECT systemKey,' + @cols + '
FROM
select systemKey, timestamp, value
) x
pivot
sum(value)
for timestamp in (' + @cols + ')
) p '
execute(@query)
Thanks xbalayer, I really appreciate it. Have a great day.
You can use a transform. The SQL query returns 3 columns: time, metric, value. You need 2 columns: time, [value], where [value] has the contents of value but the column name of metric.
Use regular SQL query with 3 columns, then add transforms:
Grouping to matrix
- Column: metric
- Row: time
- Cell value: value
Organize fields:
- Rename the time column back to “time”
Convert field type:
