How to access data from a data source when developing a plugin
I’m developing a metric panel plugin. And I need to access data from elastic data source. What is the function I should use ?
You have to create the elasticsearch data source in Grafana first. Then you select it in your panel under the metric tab.
Marcus
Hi, can you please tell me how can I identify the change in datasource from my react panel?
