i am facing errors while doing npm install for the first time in the code
i have installed all the dependencies in my machine
Follow the instructions for building from source:
http://docs.grafana.org/project/building_from_source/
If you are developing and making changes, then after following the instructions to yarn install --pure-lockfile
, use the following commands:
bra run
(to run Grafana in development mode with a watcher for the Go code). -
npm run watch
(to build and watch the front end code).
i am facing problems while doing npm install for the first time
i have installed all the dependencies required
@shikhar did you get an error when executing these?
npm install -g yarn
What error did you get? (Can you paste the error here)
@daniellee i get this error while executing the second command
An unexpected error occurred: “https://registry.npmjs.org/yarn: self signed
certificate in certificate chain”.
Sounds like a problem with your computer or network (it could be a proxy/VPN/firewall problem). Have you tried googling the error? For example, on StackOverflow:
