How to display multiple values outputs for a variable in a single Table?
I have a multi value variable in a dashboard.
Currently, for each value of the variable I am displaying a table to the user using the repeat option parameter in the component.
Instead of having one table per value, I am looking for a way to have only one table for all the variable values.
I am using InfluxDB for data storage.
Have you tested the transform → outer join?
It did the trick. Thank you!
Hi @eriktar @dma092 @
i am one the user of OpenNMS & grafana. When i install the Grafana 7.5.7 along with plugin in ubuntu server 18.04. we are not getting node and other data value in dashboard.
what we have to do for getting data in dashboard.
Error snapshot.
Please open a new thread with a meaningful subject name, as this is not
related to the thread you have replied to.
(a) People are less likely to respond to your question when it is in an
unrealted thread, and (b) a new thread will help anyone in the future
searching for a similar problem to be able to find the discussion.
Thanks,
Antony.
@pooh kindly u loop in that thread.
unable to find required thread
Please create a new question.
Antony.
