How to filter panels in dashboard using variables
    8.0.6
    I have multiple panels, want to filter it out based on the value chosen from the variable.
    I created a variable and populated pre-defined values to it. marked this variable to chose one value at a time.
  • What happened?
    I am able to apply this filter in the query of each panel, however panels are appearing blank and they are still displayed in the dashboard.
My expectation is to hide those panels that doesn’t match to the criteria. that means, to display panels that match to the value selected from the variable.
    I didn’t receive any error.
Hi @vjsre
I think you should examine this example dashboard on our public sandbox:
https://play.grafana.org/d/000000056/templated-dynamic-dashboard?orgId=1&var-app=backend&var-server=backend_01&var-server=backend_03&var-interval=1h
the number of panels changes based on the number of servers that you choose from the variable dropdown. I would inspect how this dashboard uses template variables and try to replicate the pattern
