Panel Selection
I have 10 to 13 panels in dashboard, While loading dashboard I want to display only selected panels.
How to make this possible.
Is there possible via using variables.
Can anyone share the steps to do it
Can you explain what you mean by selected panels ? Do you want to hide specific panels based on variables ?
Good Luck
yes exactly,
I want to have a variable to select a panels/widgets in dashboard for display , unselected panels should be in hide.
This can be achieved using the repeat panel :
Have a look at this.
Hope it helps.
Good Luck
