I’m doing some custom datasource plugin development, and the data is generally rendering fine, but sometimes there are null values which I want to render as gaps, but I can’t get this working. I can’t just include the null values because that throws errors when Grafana tries to render them. I found that data frame time
fields apparently have a config property which can contain an interval
property to handle this. Any values in my data which are not found at each time interval should be considered null and should render as gaps. The problem is that it doesn’t work…I can’t figure out how to cause gaps. Any help?
The data frame field interval config isn’t well documented, so I’m sort of stumbling around in the dark. I found source code references here:
and an example datasource using it here:
But I can’t get it working. Here is an example of the data frames object I’m returning from my query method:
"data": [
"refId": "A",
"fields": [
"name": "Time",
"type": "time",
"config": {
"interval": 60000
"values": {
"buffer": [
1645747380000,
1645747440000,
1645747500000,
1645747560000,
1645747620000,
1645747680000,
1645747740000,
1645747800000,
1645747860000,
1645747920000,
1645747980000,
1645748040000,
1645748100000,
1645748160000,
1645748220000,
1645748280000,
1645748340000,
1645748400000,
1645748460000,
1645748520000,
1645748580000,
1645748640000,
1645748700000,
1645748760000,
1645748820000,
1645748880000,
1645748940000,
1645749000000,
1645749060000,
1645749120000,
1645749180000,
1645749240000,
1645749300000,
1645749360000,
1645749420000,
1645749480000,
1645749540000,
1645749600000,
1645749660000,
1645749720000,
1645749780000,
1645749840000,
1645749900000,
1645749960000,
1645750020000,
1645750080000,
1645750140000,
1645750200000,
1645750260000,
1645750320000,
1645750380000,
1645750440000,
1645750500000,
1645750560000,
1645750620000,
1645750680000,
1645750740000,
1645750800000,
1645750860000,
1645750920000,
1645750980000,
1645751040000,
1645751640000,
1645754400000,
1645754520000,
1645754580000,
1645755840000,
1645756020000,
1645756980000,
1645760340000,
1645760820000,
1645760880000,
1645761060000,
1645761180000,
1645761540000,
1645764960000,
1645765020000,
1645765260000,
1645765320000,
1645765440000,
1645765500000,
1645765620000,
1645765680000,
1645766100000,
1645766400000,
1645766460000,
1645766520000,
1645766640000,
1645766760000,
1645766940000,
1645767960000,
1645768740000,
1645769580000,
1645770240000,
1645770480000,
1645771500000,
1645772100000
"name": "Value",
"type": "number",
"config": {
"displayName": "median"
"values": {
"buffer": [
8.0078787878788,
13.857142857143,
7.0861111111111,
7.0632653061224,
7.0741935483871,
7.0594713656388,
7.0656862745098,
7.0630541871921,
7.0622317596567,
8.0368421052632,
9.0818181818182,
8.0103448275862,
7.0957983193277,
7.07578125,
8.0518518518519,
9.0333333333333,
7.0350318471338,
7.0637037037037,
7.040625,
7.0237288135593,
7.0651162790698,
7.095,
13.4,
9.0666666666667,
9.08,
7.0767123287671,
7.0611940298507,
7.0794871794872,
12.833333333333,
8.03125,
7.0823008849558,
7.0617021276596,
7.0306976744186,
7.0333333333333,
7.0495652173913,
7.0626262626263,
8.0478260869565,
7.0710144927536,
7.0616438356164,
7.0702380952381,
7.0623529411765,
7.0429169157203,
8.0759465478842,
7.0515651678998,
7.0634453781513,
7.0826446280992,
7.0879032258065,
7.08,
8.0333333333333,
7.0793103448276,
7.0668224299065,
11.96,
8.0192307692308,
7.0768235294118,
7.0839682539683,
7.0539085545723,
7.0373182552504,
8.0631578947368,
18.5,
7.0435225618632,
7.0281024819856,
7.0219696969697,
14.5,
14.2,
78.5,
49.5,
8.0666666666667,
10.6,
61.5,
48.5,
43.5,
13.5,
12.333333333333,
9.05,
12.5,
45.5,
12.25,
10.5,
28.5,
89.5,
52.333333333333,
28.5,
33.5,
31.5,
35.333333333333,
9.05,
44.5,
46.5,
32.5,
11.5,
29.5,
11.076923076923,
7.075,
8.0666666666667,
38.5,
48.5,
50.5
"labels": {
"collector": "statsd",
"source": "circonus-agent",
"statsd_type": "timing"
"target": "A"
"refId": "A",
"fields": [
"name": "Time",
"type": "time",
"config": {
"interval": 60000
"values": {
"buffer": [
1645747380000,
1645747440000,
1645747500000,
1645747560000,
1645747620000,
1645747680000,
1645747740000,
1645747800000,
1645747860000,
1645747920000,
1645747980000,
1645748040000,
1645748100000,
1645748160000,
1645748220000,
1645748280000,
1645748340000,
1645748400000,
1645748460000,
1645748520000,
1645748580000,
1645748640000,
1645748700000,
1645748760000,
1645748820000,
1645748880000,
1645748940000,
1645749000000,
1645749060000,
1645749120000,
1645749180000,
1645749240000,
1645749300000,
1645749360000,
1645749420000,
1645749480000,
1645749540000,
1645749600000,
1645749660000,
1645749720000,
1645749780000,
1645749840000,
1645749900000,
1645749960000,
1645750020000,
1645750080000,
1645750140000,
1645750200000,
1645750260000,
1645750320000,
1645750380000,
1645750440000,
1645750500000,
1645750560000,
1645750620000,
1645750680000,
1645750740000,
1645750800000,
1645750860000,
1645750920000,
1645750980000,
1645751040000,
1645751640000,
1645754400000,
1645754520000,
1645754580000,
1645755840000,
1645756020000,
1645756980000,
1645760340000,
1645760820000,
1645760880000,
1645761060000,
1645761180000,
1645761540000,
1645764960000,
1645765020000,
1645765260000,
1645765320000,
1645765440000,
1645765500000,
1645765620000,
1645765680000,
1645766100000,
1645766400000,
1645766460000,
1645766520000,
1645766640000,
1645766760000,
1645766940000,
1645767960000,
1645768740000,
1645769580000,
1645770240000,
1645770480000,
1645771500000,
1645772100000
"name": "Value",
"type": "number",
"config": {
"displayName": "p95"
"values": {
"buffer": [
71.375,
174.44444444444,
94.333333333333,
113.33333333333,
21.833333333333,
43.5,
96.333333333333,
83.5,
21.333333333333,
175.71428571429,
191.66666666667,
173.33333333333,
102.85714285714,
96.333333333333,
116.66666666667,
117.5,
9.02,
93.5,
11.666666666667,
11.285714285714,
92.5,
146.66666666667,
172,
145,
105.71428571429,
103.33333333333,
106.66666666667,
107.5,
136.66666666667,
132.5,
101.42857142857,
99.666666666667,
9.0166666666667,
13.333333333333,
82.5,
106,
183.33333333333,
12.666666666667,
71.666666666667,
113.33333333333,
92.333333333333,
58.857142857143,
103.75,
31.375,
15.5,
102.5,
87.5,
57.5,
96.666666666667,
9.0833333333333,
9.0555555555556,
182.5,
91.666666666667,
93.714285714286,
94.333333333333,
17.714285714286,
16.5,
97.5,
155,
29.333333333333,
11.75,
8.0928571428571,
185,
178,
185,
186.66666666667,
56.5,
145,
80.5,
115,
125,
81.5,
1850,
27.5,
115,
125,
1650,
30.5,
99.5,
2050,
2350,
93.5,
39.5,
55.5,
47.5,
55.5,
86.5,
5050,
59.333333333333,
365,
54.5,
63.5,
57.5,
52.5,
62.5,
82.5,
495
"labels": {
"target": "A"
"refId": "A",
"fields": [
"name": "Time",
"type": "time",
"config": {
"interval": 60000
"values": {
"buffer": [
1645747380000,
1645747440000,
1645747500000,
1645747560000,
1645747620000,
1645747680000,
1645747740000,
1645747800000,
1645747860000,
1645747920000,
1645747980000,
1645748040000,
1645748100000,
1645748160000,
1645748220000,
1645748280000,
1645748340000,
1645748400000,
1645748460000,
1645748520000,
1645748580000,
1645748640000,
1645748700000,
1645748760000,
1645748820000,
1645748880000,
1645748940000,
1645749000000,
1645749060000,
1645749120000,
1645749180000,
1645749240000,
1645749300000,
1645749360000,
1645749420000,
1645749480000,
1645749540000,
1645749600000,
1645749660000,
1645749720000,
1645749780000,
1645749840000,
1645749900000,
1645749960000,
1645750020000,
1645750080000,
1645750140000,
1645750200000,
1645750260000,
1645750320000,
1645750380000,
1645750440000,
1645750500000,
1645750560000,
1645750620000,
1645750680000,
1645750740000,
1645750800000,
1645750860000,
1645750920000,
1645750980000,
1645751040000,
1645751640000,
1645754400000,
1645754520000,
1645754580000,
1645755840000,
1645756020000,
1645756980000,
1645760340000,
1645760820000,
1645760880000,
1645761060000,
1645761180000,
1645761540000,
1645764960000,
1645765020000,
1645765260000,
1645765320000,
1645765440000,
1645765500000,
1645765620000,
1645765680000,
1645766100000,
1645766400000,
1645766460000,
1645766520000,
1645766640000,
1645766760000,
1645766940000,
1645767960000,
1645768740000,
1645769580000,
1645770240000,
1645770480000,
1645771500000,
1645772100000
"name": "Value",
"type": "number",
"config": {
"displayName": "p99"
"values": {
"buffer": [
87.5,
265,
177.5,
203.33333333333,
65.5,
195,
195,
175,
87.5,
213.33333333333,
315,
298,
173.33333333333,
185,
206.66666666667,
233.33333333333,
23.5,
175,
36.5,
25.666666666667,
165,
195,
236.66666666667,
205,
175,
215,
215,
175,
315,
205,
186.66666666667,
175,
23.5,
93.5,
126.66666666667,
235,
206.66666666667,
75.5,
405,
225,
186.15384615385,
90.117647058824,
195,
81.111111111111,
103.33333333333,
176.66666666667,
206.66666666667,
107.5,
173.33333333333,
39.5,
20.5,
286,
145,
188.33333333333,
176,
87.666666666667,
64.5,
195,
245,
98.5,
65.25,
55.333333333333,
185,
2033.3333333333,
185,
186.66666666667,
56.5,
176.66666666667,
80.5,
115,
165,
81.5,
1850,
27.5,
1950,
355,
1650,
30.5,
2150,
2050,
2350,
93.5,
39.5,
55.5,
47.5,
55.5,
86.5,
5050,
59.666666666667,
365,
54.5,
79.5,
57.5,
52.5,
62.5,
82.5,
495
"labels": {
"target": "A"
"refId": "A",
"fields": [
"name": "Time",
"type": "time",
"config": {
"interval": 60000
"values": {
"buffer": [
1645747380000,
1645747440000,
1645747500000,
1645747560000,
1645747620000,
1645747680000,
1645747740000,
1645747800000,
1645747860000,
1645747920000,
1645747980000,
1645748040000,
1645748100000,
1645748160000,
1645748220000,
1645748280000,
1645748340000,
1645748400000,
1645748460000,
1645748520000,
1645748580000,
1645748640000,
1645748700000,
1645748760000,
1645748820000,
1645748880000,
1645748940000,
1645749000000,
1645749060000,
1645749120000,
1645749180000,
1645749240000,
1645749300000,
1645749360000,
1645749420000,
1645749480000,
1645749540000,
1645749600000,
1645749660000,
1645749720000,
1645749780000,
1645749840000,
1645749900000,
1645749960000,
1645750020000,
1645750080000,
1645750140000,
1645750200000,
1645750260000,
1645750320000,
1645750380000,
1645750440000,
1645750500000,
1645750560000,
1645750620000,
1645750680000,
1645750740000,
1645750800000,
1645750860000,
1645750920000,
1645750980000,
1645751040000,
1645751640000,
1645754400000,
1645754520000,
1645754580000,
1645755840000,
1645756020000,
1645756980000,
1645760340000,
1645760820000,
1645760880000,
1645761060000,
1645761180000,
1645761540000,
1645764960000,
1645765020000,
1645765260000,
1645765320000,
1645765440000,
1645765500000,
1645765620000,
1645765680000,
1645766100000,
1645766400000,
1645766460000,
1645766520000,
1645766640000,
1645766760000,
1645766940000,
1645767960000,
1645768740000,
1645769580000,
1645770240000,
1645770480000,
1645771500000,
1645772100000
"name": "Value",
"type": "number",
"config": {
"displayName": "upper"
"values": {
"buffer": [
215,
885,
295,
305,
185,
285,
375,
555,
295,
286.66666666667,
625,
386.66666666667,
195,
775,
495,
455,
73.5,
205,
96.5,
605,
275,
206.66666666667,
365,
245,
255,
285,
275,
5050,
435,
216.66666666667,
285,
245,
135,
215,
255,
275,
535,
295,
815,
275,
495,
905,
2450,
375,
175,
205,
265,
115,
255,
615,
64.5,
2250,
365,
296.66666666667,
216.66666666667,
275,
425,
215,
395,
305,
176.66666666667,
61.5,
185,
2550,
185,
186.66666666667,
56.5,
275,
80.5,
115,
165,
81.5,
1850,
27.5,
1950,
355,
1650,
30.5,
2150,
2050,
2350,
93.5,
39.5,
55.5,
47.5,
55.5,
86.5,
5050,
59.666666666667,
365,
54.5,
94.5,
57.5,
52.5,
62.5,
82.5,
495
"labels": {
"target": "A"
"t": "ts"
