How to set a default value for a variable?
How can I have my variable select a different default value other than the first one?
I see it might be possible according to this thread but I see nothing about it in the docs nor UI.
Thanks!
Any ideas? The default All is not being chosen, 0 is which never has values - annoying.
Select the preferred value and then save dashboard + check Save current variables:
We tried that, but that does not work when NO value is selected for a variable. We would like to have an “empty” dashboard where everything is setup as we need, and no variable has any value selected. Can that be achieved too ?
Solved it in a hacky way : https://localhost:3000/t/default-none-dummy-option-for-template-variables/17951/6
you can define Additional variable, like “None” and make it default for the dashboard.
