If you mean the end-of-test summary that k6 emits, then unfortunately you can’t easily discard or ignore them…
Add explicit tracking and ignoring of metrics and sub-metrics · Issue #1321 · grafana/k6 · GitHub is a proposal for a way to do that, but it’s not implemented yet. It (or something like it) is high on our priority list, but I can’t give you an ETA yet, sorry…
If you use an external output like InfluxDB/k6 cloud/etc., you can filter out setup()
and teardown()
metrics by their group
or scenario
tags.
Hmm, actually, you can use that and a few other tricks to filter out setup()
and teardown()
metrics in the end-of-test summary even now! Because you can (1) define thresholds on tags and (2) these threshold definitions generate sub-metrics, which are displayed in the end-of-test-summary, and (3) post-v0.27.0 you can apply tags in each k6 scenario!
So, something like this:
import http from 'k6/http'
export let options = {
vus: 5,
duration: "10s",
thresholds: {
// We're using 'scenario:default' because that's the internal k6
// scenario name when we haven't actually specified `options.scenarios`
// explicitly and are just using the old execution shortcuts instead...
'http_req_duration{scenario:default}': [
// Some dummy threshold that's always going to pass. You don't even
// need to have something here, I tried it and just this
// `'http_req_duration{scenario:default}': []` is enough to trick
// k6, but that's undefined behavior I can't promise we won't break
// in the future...
`max>=0`,
export function setup() {
http.get('https://httpbin.test.k6.io/delay/5?stage=setup')
export default function () {
http.get('http://test.k6.io/?where=default')
http.get('https://httpbin.test.k6.io/delay/1?stage=default')
export function teardown() {
http.get('https://httpbin.test.k6.io/delay/7?stage=teardown')
will result in an end-of-test summary like this:
data_received..............: 497 kB 21 kB/s
data_sent..................: 11 kB 442 B/s
http_req_blocked...........: avg=47.02ms min=2.48µs med=5.49µs max=541.85ms p(90)=173.73ms p(95)=407.58ms
http_req_connecting........: avg=19.31ms min=0s med=0s max=132.97ms p(90)=131.37ms p(95)=132.16ms
http_req_duration..........: avg=775.35ms min=136.49ms med=1.13s max=7.13s p(90)=1.13s p(95)=1.14s
âś“ { scenario:default }.....: avg=641.27ms min=136.49ms med=644.4ms max=1.15s p(90)=1.13s p(95)=1.14s
http_req_receiving.........: avg=3.76ms min=61.65µs med=896.96µs max=17.83ms p(90)=11.89ms p(95)=14.19ms
http_req_sending...........: avg=56.48µs min=14.18µs med=44.96µs max=331.36µs p(90)=108.14µs p(95)=127.76µs
http_req_tls_handshaking...: avg=24.36ms min=0s med=0s max=341.86ms p(90)=0s p(95)=276.07ms
http_req_waiting...........: avg=771.52ms min=133.11ms med=1.13s max=7.13s p(90)=1.13s p(95)=1.14s
http_reqs..................: 82 3.402872/s
iteration_duration.........: avg=1.46s min=1.27s med=1.28s max=5.67s p(90)=1.87s p(95)=1.87s
iterations.................: 40 1.659938/s
vus........................: 0 min=0 max=5
vus_max....................: 5 min=5 max=5
Notice how the âś“ { scenario:default }
row doesn’t contain the long setup()
and teardown()
times. You can do this even if you have multiple scenarios
, but then you’d have to add tags
for each one. On the flip side, that gives you even more flexibility, you’d be able to get any number of cross-sections for each sub-metric.
See the last example from the “Advenced examples” section in the scenarios
docs (sorry, can’t link directly to it), the one with:
thresholds: {
// we can set different thresholds for the different scenarios because
// of the extra metric tags we set!
'http_req_duration{test_type:api}': ['p(95)<250', 'p(99)<350'],
'http_req_duration{test_type:website}': ['p(99)<500'],
// we can reference the scenario names as well
'http_req_duration{scenario:my_api_test_2}': ['p(99)<300'],
If you run that, the end of test summary will look somewhat like this:
http_req_duration..............: avg=140.2ms min=131.85ms med=136.63ms max=233.94ms p(90)=149.76ms p(95)=154.92ms
âś“ { scenario:my_api_test_2 }...: avg=148.57ms min=139.63ms med=145.59ms max=233.94ms p(90)=157.21ms p(95)=167.33ms
âś“ { test_type:api }............: avg=148.95ms min=139.63ms med=145.69ms max=233.94ms p(90)=158.46ms p(95)=168.87ms
âś“ { test_type:website }........: avg=135.07ms min=131.85ms med=134.01ms max=160.74ms p(90)=139.29ms p(95)=140.97ms
