Is there any plugin to pass json data to grafana?
My requirement is to pass the monitoring data from my custom solution which is in the json format. I can see the enterprise plugins out there but i couldn’t find any plugin for incoming webhook for Grafana cloud.
I can see simple json plugin but if i put my custom http endpoint in server of data source setting and create a dashboard, i should have seen somthing in the query but it is showing no metric.
Or I would appreciate if you suggest any other recommeded way to pass the json data.
